want to get some wheel spacers
im89
whats a good brand and is there something that i need to look for beside the amount of space? i have the stock 09 18" rims personally i like them but want to put spacers on them any suggestions on the size of spacers i should use? Would 15mm in the front and 20mm in the back be good? and is ichiba v2 any good i see some on ebay so i was think about buying those just want to check with you guys first.
Modified by im89 at 3:08 PM 1/11/2010
Loop
Car: only nissan cars
im89 wrote:whats a good brand and is there something that i need to look for beside the amount of space? i have the stock 09 18" rims personally i like them but want to put spacers on them any suggestions on the size of spacers i should use? Would 15mm in the front and 20mm in the back be good? and is ichiba v2 any good i see some on ebay so i was think about buying those just want to check with you guys first.
I have used Project Kics WT and Ichiba v1 spacers. They are both great brands and you can't go wrong with them. Project Kics are a little more expensive and does not include hub centric rings. While Ichiba v2 have a built in center bore.
Check your wheels for open slots or cavities if you are going to use Ichiba v2 spacers or Kics WT. Though you may be able to pass if you go with a big enough spacer since OEM studs are short from the start. The wheel just needs to be flushed against the spacer.
These are the specs you need:Bolt Pattern: 5 x 114.3Center Bore: 66.2Thread: 12x1.25
I can't recommend on how much space as I don't know what your goal is other than pushing it out more. But how much more? Describe what your looking for so NICO members can help you out!
im89
Honestly im not looking for anything to crazy dont want my tires poppin out....went to a rim shop just now i they recommended i didnt use it told me 10mm spacers are thick and if i put those on my tires would be poking out. Just want it to as close to the fenders without having to roll them. Dont really want to change my stock rims because im planning to get them powder coated but the back rim to come out a little.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
10mm spacers shouldn't be too thick. stock rims are +45 offset, I'm on +33 offset G35 rims which sit really flush with the fender, but do not stick out past the fender for sure. I'm also on wider rims, stock rims are 7" and I'm on 8.5" rims.
If you want to figure out how thick of a spacer you can use, just measure the gap between the edge of the fender and your rim, as long as the spacer isn't thicker than that then you should be A-OK.
