Walbro High-Preasure Fuel Pump.......
Bobby_Wu
Has anyone installed or know someone that has installed a Walbro High-Preasure Fuel Pump.... the 255LPH High Preasure fuel pump...i have a 1995 240sx ...I've seen numours sites selling the pump for the 1991 to 1994 240sx...will i be able to install that pump in to my 95 240sx???...i've read that you need to use your stock pickup sock in the install??
NISMO24096
doing that same install now is it true that you need to use the stock pickup sock if so i need to go get a new one from nissan,,,please reply if you know for sure thanks.....Lee
SCOOBYSHAG
ive installed it on my 91 S13 and it was a simple install. no problems as of yet either
NISMO24096
by chance did you notice that you ran out of gas earler then with the stock sock???
SCOOBYSHAG
actually i am still on my first tank of gas with both my car and the pump...just got my car two weeks ago and that was the first mod i did
NISMO24096
well let me know if you run out before you hit E or before you light comes on......
SCOOBYSHAG
ok
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
I just installed mine too. About a month and a half ago. I used the sock that came with the kit. No problem as of yet. My gas light comes on at E than I fill up a little half past E. Haven't noticed any performance increase yet. got to go to tracks (1/4m) to see for sure . Maybe friday. Then drift session on sunday. But one thing I did notice was my gas mileage. Before I used to hit about 280-300 miles per tank. I just filled up on sunday checked the tripmeter and wowee 361 miles were registered.
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
The sock is for the s13 in the walbro units and is good for the s13... For an s14 the included sock is not only too short (due to different tank designs) but also facing the wrong direction...
Check the access panel post for my link to a archived freshalloy post on the sock, and a damn close (images are down last time I checked but still) replacement... It also states where to get this sock so that the s14 walbro runners have an alternative to running out of fuel with plenty in the tank(a very good possibility for the auto-x'rs who like to run lower fuel levels to save weight like myself).
D-UNIT
^^yup
Structure240sx
**** i jsut put im my walbro with the sock that it came with. i thought about it with the stock sock being like 7 inches longer. guess i might be redoin it
NISMO24096
good thing i waited until i got my replys to put mine back in, but i did already put the short one on the unit but that will be easy to take off and get a new sock from nissan, does any one know how much they are from nissan or if you can even buy them seperatly? thanks Lee
Structure240sx
i dont know how much it is but u can buy every bolt to the car separatly from nissan
96_S14_SE
[email protected] is the email for the business who knows what is up with the sock to use for the s14, and walbro 255.
Just give them an email and ask for the s14 sock TY used on the walbro as found on freshalloy.
Structure240sx
thanks man i jsut sent them an email
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Where have you all purchased the Walbro pumps? Also, I've been told to use the 225 unit not the 255. Any thoughts?
96_S14_SE
I got mine from enjuku as I was planniing on going turbo soon after I bought it, and had to drive by and get some other goodies. Things didnt work out so I sold it, as I never installed it, but I did reasearch the sock issue :)
Ill probably get another from enjuku as its as semi local retail shop.. Ebay is another good place..
And why not use the 255? Im just curious as to why someone told you to use a lesser pump...
Structure240sx
i got mine with my nsport kit
