biosehnsucht wrote:thats what turns me off from SDS and most other standalones.. have to replace all the (more or less) prefectly good OEM sensors for cam/crank/whatever timing etc... and rig up specially modified pullies and such to do it.. I wouldn't want to have to trust that sort of stuff to a daily driven car..
not to say others haven't done it w/o problems (altho others HAVE with problems)
Seeing that CA18DET has been in existence for over 20 years, an update in engine management wouldn't hurt at all. And seeing that everyone and his moma is having problems with electrical dramas up to and including those trustworthy (yeah right) factory sensors, for the amount of headaches, lost time at work, sleepless nights, etc, etc, for a few extra dollars, you'd be surprised as to what a fine standalone system can do. And to those who are in emissions-based environments, this would make a perfect system for you.
The ability to control ignition timing, fuel and most parameters is a needed thing especially when your car is sayyyy 'running too rich and you need to lean the hell out of it'. The SDS system is one of the few that does not incorporate nissan's beloved crank angle sensor which to me is a demon in disguise that will give you issues without prompting a code.
But then again, it's your money, your car and you're free to do whatever you think will assist you in achieving your goals. BTW, my woman's sentra has a A/C and P/S and it fast idles just as good as any normal OEM set-up. So it's all about who's installing and what they want out of it; oh yeah, and how much you know about what you're messing with.
float_6969 wrote:
I've got to agree with you 100% here. I'm quite anal about, well everything, and especially when it comes to wiring. But I have, on multiple occasions, been told that my wiring jobs look factory. I pride myself on that and I know that I've got a very good grasp on the wiring aspect of it. I read the entire manual last night and, as the name implies, the entire system is quite simple. Making the bracket for the Hall sensor and mountin the mangnets should be the only hard part, and I'm not too worried about that either.
I did have a new development yesterday though. When I pulled the cover off of the unit to get the serial # so I could get some info about it from SDS I found some corrosion on the circut board. I cleaned it up really well and when I put power to it yesterday, it seemed to work OK. I obviously don't have everything hooked up, but I may have to send it off to have them check it out. We'll see what happens...
And Ryan, corrosion inside your ecu is bad. I would send it to racetec and have them check it before you decide to play. Or install everything and see if it would crank. And BTW, those magnets are very fun to put in . Remember position, position, position.
Dee
