i am thinking of ditching the NISSAN CAS in favour for teh hallsensor.. i have 4 sensors and all have their quirks... i thought that once set up right those hall sensor and similar trigger wheels ar better and more accurate...float_6969 wrote:Update:
I'm still quite confused on the Hall sensor bracket, but may have an alternative. BioSehnSutch is currently developing a Hall sensor converter for the SDS system. Basically what it would do is use the stock CAS, convert the signal and output it to SDS ECU. That means no bracket to make, no removing the crank, no drilling, and no magnets! If we can get this to work, I'm going to see if SDS would be willing to list a "Nissan" kit that would lack the Hall sensor and magnets. This should work on basically any newer (Mid-80's and up) Nissan. The current program is for 4cyl, but it should only require some minor re-programming for the V6's. If we can get it to work it will MAJORLY simplify the installation of the SDS unit on a Nissan.
You are flirting with disaster. Stop being lazy and make the hall sensor or pay someone to do it . The only system they have that will work with nissan systems is the D system which is designed for cars with distributors. Haltec and microtech standalones can be triggered by nissan/mitsubishi/hitachi's crank angle sensors. SDS cannot as it is triggered by true earth magnets. Ryan, take my advice and just get a bracket made. It ain't cheap, but it's worth every $ you spend.float_6969 wrote:Update:Ok, so I should have the ECU back from Racetech on friday. They said that it seemed perfectly fine. They said that it was pretty common for them to get wet and not work and then when the dry out, work again. So it seems that I got a pretty good deal then. After getting the update and buying some sensors and getting a couple of extra options added when they had the computer the grand total STILL came up to less than 1K. Still not bad in my book.
That bracket is pretty simple, but a prototype would help even more for degrees of angle and final sensor positioning. Remind me during the weekend to get you some pics of my hall sensor bracket. Mine is currently off the engine because the engine is sitting at a machine shop waiting for yet a 3rd crank since the last one I had was bent and had a warped nose where the flywheel sits.float_6969 wrote:w00t! I just got it back. It's like 9am on Friday. They mailed it back to me the day after they got it. They have to have THE BEST customer service I've ever encountered. I mean, I didn't even really buy the product from them. Anyway, I'm impressed.
As for the car and installing it, I plan on getting started next week. I'm contemplating hooking the car up normally and getting it all tuned and everything and THEN trying out the thing that Sehn is working on for me. We'll see how modivated I get. Plus it'll take me a couple of weeks to get the few hundred it's gonna cost me a to have the bracket made and the magnets mounted. Oh well, gotta pay to play, right?
