Older Specs have the same engine as yours. the only difference is updated design and re-tune.aebstract wrote:The older specs are a smaller engine though, makes sense and I wouldn't expect them to win stock vs stock at all.
Id imagine the Sentra would win. Same engine less weight.08Sentra wrote:Nice one man. I always wanted to see how the spec-v and the altima would fare side by side.
Be safe out there.
the current QR25 in the SpecV is known as the QR25HO, with the Altima sits about the same as the SE-R. Ao 200hp vs 177, hrmmmm, not quite the same HP, but still a negligable differance.spec_v03 wrote:umm, the B15 and B16 chassis have the same size motor. 2007+ QR25s make slightly more HP though.the same motor is also in the 2.5L altima. And as mentioned before, sentras weigh less, so that gives you an upper hand.
