VQ35DE VS VQ35HR
Hussain
Car: 08 Altima Coupe 3.5se CVT
what's the difference? i know the HR is faster but why? and i heard our V6 A/C have HR heads, is that true?
mcheddadi
Car: R8
The VQ35HR has slightly different cam timings than the VQ35DE 'Revup'.
VQ35DE 'Revup' cam data
Engine: VQ35DE (3)Model Years: 2005-2006 (G35mt, 35th Anniversary 350Z)CVTC: Intake and Exhaust
Intake__Lift: 10.5mmExhaust_Lift: 10.5mm
Intake__Duration: 248ºExhaust_Duration: 248º
Intake_Opens: 2º ATDCIntake_Closes: 70º ABDC
Exhaust_Opens: 70º BBDCExhaust_Closes: 2º BTDC
Overlap: -4º----------------
VQ35HR
Engine: VQ35DECVTC: Intake and Exhaust
Intake_Opens: 2º BTDCIntake_Closes: 66º ABDC
Exhaust_Opens: 68º BBDCExhaust_Closes: 0º BTDC
Overlap: 2º
The intake cam has been advanced by 4º and the exhaust cam has been advanced by 2º.
The spark plug lised in the ESM is the Denso FXE22HR11
Same smaller valves as on the 2007 Altima.
Stiffer valve springs than the 'revup' engine. Strongest springs to date on any known production VQ engine. They might be the same as the Nismo springs.
113-127lbs @ 26.2mm (vs. 98-110lbs @26.2mm revup)
Once piece main cap/girdle/skirt with six bolt mains. Similar or same design as the VQ40DE.
Suspisions about longer rods aren't true. The VQ35HR has the SAME 144.2mm rod length as all other VQ35s. Unless the ESM is wrong. But this block is supposed to be taller. The different might all be in the piston height.However it does have 57mm journals vs. the old 55mm journals (without bearing).54mm vs. 52mm Crank journals.Main crank journals increased to 64mm, up from 60mm.Main crank bearings thickened to 2.5mm up from 2.0mm.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Nice write up
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
adidas2go wrote:Nice write up
I don't know what half of it means, lol.
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
Excellent info mcheddadi!! That has answered the majority of the questions i've had with the differences in this engine.
Sounds like the secret to bump 300 hp naturally aspirated is a couple of bump sticks
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Nice write up one morw thing...Don't forget nissan went to a dual intake on the newer Z's as well. mI think end of 2006
rn79870
Car: 2008 G35 & 2005 Vette C6 vert.
Nice work. That is interesting.
mcheddadi wrote:----------------The VQ35HR has the SAME 144.2mm rod length as all other VQ35s. Unless the ESM is wrong. But this block is supposed to be taller. The different might all be in the piston height.
I think that the rods might be a little longer. Here is some info on the HR.
http://www.vq35hr.com/tech.shtml
