a hot pink differential?!! That would look like a pair of balls under the carjeff420 wrote:cant wait to install my new vlsd, its pretty. painted it orange. couldnt find hot pink paint, lol.
What spank said is textbook and is really the only to try to visualize how the vlsd worksspank044 wrote:OP, buy it.
A vlsd has a sealed viscous coupling which has 2 or 3 slotted discs submerged in a thick silicone based fluid, when the disc start to slip under hard acceleration then the fluid gets hot and hydraulically binds the discs together to make both output shafts spin at equal rates.
NOOOOOOOOOOO dude you cant tell a newb to pull his diff apart and throw some shims at it ... the shims are there for a reason ( to set backlash on your ring and pinion gear ) if you have to much left or right it will cause your center-section to be off and whine or chatter and it would kill his pinion gear and bearing trust me not a good ideaspooled240 wrote:hell yes the vlsd will be a night/day difference compared to the open diff. No more one wheel burnouts on hard launches or hard cornering and a lot more added traction in rain/snow/mud.
I heard that the vlsd unit is not rebuildable, or it is not designed to be rebuilt as the thick silicone-based fluid in the viscous unit is totally sealed from the gear oil you put into it. So changing the gear oil will help your vlsd last longer as far as lubrication and heat(same reason you change the oil in your car, replacing worn-out oil) but it won't rejuvenate the viscous unit persay.
There is, however a way to have your worn out vlsd to lock much better. You can shim your vlsd and depending on how thick your shims are, you can have your lsd lock like a 1.5way or a 2 way(welded) differential. A shim from nissan is around 10 bucks but you will have to open your differential up a little bit.
there is a good write-up on zilvia:http://zilvia.net/f/s-chassis/....html
or just search "shim vlsd" on google for some other results
have any dana 60's laying around from when ya worked there?..lol..thought id askBeanstalk wrote:I used to work at dana axle and guys argued about this topic all the time point is yes you can rebuild them but there are tricks that you can do to bring life back into your vlsd like friction inhibitor that big trucks use the oil in the diff should be changed and i hear you can also hose the IU down in brake parts cleaner and let it dry out then re-oil and acts as good as new
i saw the link i want to go with a 1.5 shim but it just seems a lot of people say that it can cause premature damage or mess up the rear end all altogether.spooled240 wrote:take it to a h0m0, they are rear-end specialists haha j/k
but for real, check out that link in my first post. It has pictures of a rear end and how to open it up(no h0m0)
with one shim to make it like a 1.5 way you should be fine. This is actually an old mod that has been used in racing and it's been working great for a lot of peoople.turoki wrote:
yeah thats what i heard too a bout two warping so you think the 1.49mm wouldent be to much for the spider gears?. did you shim yours up yourself ?spooled240 wrote:I heard that having double(stacked) shims can cause some warping and stuff but this is just from what I heard. If I were you I would remove the stock shim and throw the 1.49mm shim in there. Just one solid shim and you'll have a pretty damn good vlsd that won't be a full locker but also not a weak sauce lsd.
yeah im pretty good but i just never got all into diffs thats all. i heard that you need to check clearances and stuff like that or it can get major premature damage thats why im concerned.spooled240 wrote:nah I just did some research and looked at some write-ups. I never did it but it doesn't look hard at all. Are you pretty good at mechanic work?
