RB25det 1000HP Build
Discuss the RB20, RB25 and RB26 series engines.
340zxttaz
Congrats nice work keep us posted please.... :crazy: :crazy: :mike :mike :mike
RRRRB
Car: 98 RB powered S14
made any passes is this beast yet?
Jimefam
RRRRB wrote:made any passes is this beast yet?
Lol not yet, had a little technical issue first time we tried the nitrous. I got it set up and left the bottle open and line pressurized while we worked on some wiring. Well it pushed past the seal of the solenoid (turns out your supposed to purge the lines if its going to be an extended period of time) and when we turned the car on it immediately backfired so hard it took a chunk of the head off and blew a small hole in the intake manifold. Head has been rewelded but I havent had time to put it back together as ive been working alot and racing the GTR also. Hope to make an event in october and also world cup with both cars.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That sucks so much! Can you install some kind of pressure relief valve on the nitrous line to burp off the excess pressure above like 1200psi so it doesn't leak past the solenoid again?
Jimefam
Darius wrote:That sucks so much! Can you install some kind of pressure relief valve on the nitrous line to burp off the excess pressure above like 1200psi so it doesn't leak past the solenoid again?
Not sure, I will look into it though. I did swap the solenoids out for bigger better ones that should hold up better but the main thing is me properly using the nitrous and making sure if i am not spraying soon the lines are clear. Head is still sitting in my garage. Hopefully should get a break in work in a couple weeks which will give me time to put it back together and get testing.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Dang sorry to hear on the damage. :cry:
RRRRB
Bump!! Updates.....
NathanBrazil
Car: 1991 S13 Hatch RB2XDET - CP Piston, Spool Rods, HKS HG, GT3076R - Nistune
1993 Welded-diff stock a** E36 325i
any updates yet? been a while
dee242
Car: 1998 r33 gts-25t 40ae
updates
wheelzinmotion
Would love to bring this thread back from the death, with lots of updates, hoping you finally sorted out everything and are enjoying the car at the strip...
RRRRB
Bump, lolz
Return to “RB20DET / RB25DET / RB26DETT Forum”
