Well, I have some updates... Not good ones I'm afraid. I did the PRVR bypass, It didn't change anything but Its good to have one less thing to worry about. I also was able to bypass the AIV system just to see if it would make a difference, but it didn't, so i hooked it back up. I was going to cap off the extra pipes you mentioned but ran out of time as I had to go pick up my sister from the SeaTac airport (this is my only car I own).
Got stuck in traffic because anyone who lives in the I-5 corridor knows you can never depend on getting somewhere without getting stuck in a traffic jam haha. Broke free of the jam and was cruising down the highway at about 3k when i felt a sudden almost jolt/buck/surge? I'm not sure what the right word to use would be. Look down and I have a CEL. So I pull off at the nearest exit to pull the code.
Shut the car off, pull the code: 55 .... WTF you are definitely not ok car....
Play around with a few other things under the hood. Nothing looks damaged or out of place. No leaking fluids, smoke or anything like that. try and start the car and I get the craziest hunting idle and lots of stalls. pulled o2 sensors just for good measure.... same thing. Figure this is something I don't want to tinker with and continue to drive on public roads. Thank God for triple A
Roasted in the Z for almost 2 hours before the tow truck gets to me. I had been just tinkering around in the interim and noticed my condenser fan is spinning like no other when i put the ignition in the ON position, I start the car up to see what its going to do and Its idling at 2k steady. much higher than normal (I had plugged the o2s back in at this point) Time to do a little research
To me it seems like the car put itself in safety mode due to overheating. The temp gauge didn't look any higher than normal while driving but, it is a dummy gauge.
I was a bit confused about why the car would overheat, it had been topped off by the Z shop not even 2k miles ago after the 120k service. Then it hit me... What if I have been having a small head gasket leak this WHOLE time? It used to only have that shake at idle when it was warm out, then it started happening when it was cold too. And now overheating to the point of safety mode? Perhaps, and i could be wrong, but would some coolant leaking into a cylinder cause that vibration I had been dealing with? The car ran like total garbage pulling it on and off of the tow truck, and has a horrid exhaust smell. I won't know the prognosis until probably Monday but I'm pretty worried, and perhaps a bit jumpy with my conclusions.
