Sopdadope »
https://forums.nicoclub.com/sopdadope-u303.html
Sat Feb 15, 2003 2:08 pm
WOOO HOOO!!!
Here's what went down the last couple of days...
Over the last month or so, my weekends have been spent working on cars.
As you know, I tried selling a rescued-from-the-pits 240sx a month ago. The deal went pretty smoothly, but unfortunately fell through because the car suffered from severe body rust. So, I've taken the car back and have been rehabilitating whilst trying to sell of my Q.
Anyway, a friend of mine sold off his old Q and bought a tired Q for $1,400. It was in "my shop" the past couple of days for a compete overhaul: leaking turbine sensor, needs new chain guides, valve cover needs resealing, new hoses, transmission pan drop, filter change, plugs, etc., new transmission and engine mounts, o2 sensors.
My 240sx has also been at the shop, getting the big rust spots squared away with. There were trouble spots along the taillights and bigtime rusting underneath the doors.
With the use of a mallet, rivet gun, fiber-glass and some bondo, the car now looks great. My mechanic, Reth, did some TIG welding and grinding before we did the fiberglass.
The KA was running extremely rough. A compression test revealed low compression all across the board. There's a pinging sound that's very audible. We're gonna have the whole motor ripped apart to check the bottom end. So far my mechanic thinks the pistons maybe warped because of low oil level and an inadequate cooling sys (very old radiator, low coolant). The gaskets are leaking pretty badly too..
So with all the bad news, why am I so ecstatic? Because of the subzero temperate and only two lifts, we found it easier to loosen the front cross-beam, transmission mount, SB and CA's and "dropped" the entire drivetrain.
In the meantime, the KA24 and transmission came out for said bottom-end inspection and replaced the crappy Dynapak clutch I had installed a few weeks ago.
With both drivetrains out, we rolled out an old Z32 transmission core just to see if it'd bolt onto the VH45DE. Didn't work, Z32 5spd bell housing is a apprx. 2" smaller in diameter than the Q's AND the Q flywheel is an entirely different bolt pattern.
However, a custom bellhousing should work.
Again, just in case anyone's considering this, it's SO MUCH easier to access the turbine sensor with the transmission dropped.
I fooled around with the cherry picker and tried dropping the VH45DE in the 240sx with the exhaust manifold already off. To my surprise, the engine fit! I had a tape measure and measured the VH45DE at apprx. 28 3/4" from valve cover to valve cover.
The oil pan nicks the 240sx crossbeam but some hammering or a dry-sump should solve this problem. The weird bulge on the driver-side of the motor clears the steering linkage. If there ex. manifolds were on, it may not have fit but again, custom-work is needed there too.
A cowl hood is needed because this motor's too tall. A custom intake manifold is an more expensive alternative.
Despite the obstacles, I'm feelin like a sunny optimist about this. I'll have to buy a crappy disposable camera and take pictures of all this.
Oh and the 240sx needs a new front end but...in due time...
