IMPORTANT UPDATE:If you used version 2.5 of this document to build your harness, please download version 2.6 now as there were a couple of errors that have been corrected in this version. Thanks. Version 2.6 has been tested from start to finish with superhatch on his car and proves completely functional after the corrections identified were made. Thanks Stephen for your feedback and being patient as we worked through the issues on the phone.
Hello Everyone,
This is my first post contributing versus consuming the fantastic information I find here on NICO. I had not found any document like the one I created so after countless hours of pouring over electrical schematics, multimetering physical connections and transcribing hand-written notes to put this all together I thought I would post it for public consumption.
The document on the link below is a complete cross reference (source->destination) of all the wiring conversion/integration necessary to get a VH45DE into a Z32. Many Nissans are wired in a similar fashion so others may find this document useful as well. This document is intended to be a starting point, so any suggestions on how to improve are always greatly appreciated! Think of it as a Request for Comments (RFC) at this stage.
I am hosting this document on my servers so any changes incorporated will be placed in that document. This way we can have a "single source of truth" versus an attachment that can become outdated.
Caveat: I am waiting for craigztoys (hint-hint) as he's fabbing up my engine mounts and oilpan. With that said the wiring harness has not been tested. Craigztoys is also reviewing this document against his conversion with a 90 motor and we'll make updates as feedback becomes available. I will do the same when the motor is in my Z.
I hope you find this document useful and maybe it can save you the hours of work I put into it!
Good Luck with your projects!
Nick.
http://www.b2b-now.com/vh45det...g.pdf
Modified by npez at 4:14 PM 10/14/2008
Modified by npez at 4:15 PM 10/14/2008
Modified by npez at 11:45 PM 1/2/2009
Modified by npez at 12:32 AM 1/31/2009
