VH45de s14
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
SaintlyCharBoy
Car: 92 vert, KA died - awaiting VH41 + 5 speed MA5
wanna start a group buy, or will this all be done at the same time as cams become available?
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Yeh, I'll sort them out later when cams are ready.
MadmikeX3
Car: 1990 240sx SRBLKTOP With a potatoe
Any updates more on this car? Can we get a Full write up?
SuperHatch
Car: 96 TLC
MadmikeX3 wrote:Any updates more on this car? Can we get a Full write up?
He blew the motor and sold all the swap parts. No more updates besides that.
Z Style
Car: 93 240sx Roadster
01 Pathfinder Overland
97 F350 Powerstroke
88 RX-7 SR20DET Swapped
14 Star Bolt
Just curious. How did it blow and any indications of why?
tmorgan4
Car: 2000 Nissan Pathfinder
I believe he spun bearings in multiple engines.
Z Style
97 F350 Powerstroke
14 Star Bolt
tmorgan4 wrote:I believe he spun bearings in multiple engines.
Hmm. I would definately like more info on this. I might have to find a way to keep them bishez in place in my car because I know it is going to be bouncing off the rev limiter every run. Do these have a crank girdle?
T45
Car: King Kong powered Z32
Yes, all of the info on the engine is in the stickies.
tmorgan4
If you'd like any internal engine pictures I have a couple good ones I got while assembling my engine. The original suspicions for the spun bearings were thought to be due to the front sump. GS14racer and someone else (who???) both spun bearings, and were both running front sumps. I haven't heard of anyone else having an issue who has converted to a rear sump.
Not really sure if these cars are pulling enough G's on acceleration to starve the oil pickup though. They WERE designed for a front sump, after all.
Grdevs24zero
Car: '91 240 and '87 300ZXT
Carl H wrote:why not a steel spacer, wont the copper deform?
You always want to use copper or other soft metal, or else the springs will dig into the head and cause problems. The copper absorbs the beating this way, not the head.
Grdevs24zero
Ha, apparently that was my first post ever on these forums. I swear I've been a member longer than my profile states though. Oh well.
Z Style
97 F350 Powerstroke
14 Star Bolt
tmorgan4 wrote:If you'd like any internal engine pictures I have a couple good ones I got while assembling my engine. The original suspicions for the spun bearings were thought to be due to the front sump. GS14racer and someone else (who???) both spun bearings, and were both running front sumps. I haven't heard of anyone else having an issue who has converted to a rear sump.
It sounds like the same issue that the KAs have when drifting. You have to keep them over fill or else they starve for oil when sliding. I have witnessed two local KAs do this because people don't keep their oil at atleast the fill mark.
gs14racer
well its about time to bring this thread back from the dead, after boiling over this for the past few months then regretting i sold the whole setup, then doing the sr20det, i got another low mileage clean vh45de with good maintence. Its a 95 motor and runs good, the only thing i can tell thus far it has wrong with it is it barfs some black smoke from time to time. Probably has an injector or two bad, or sparkplugs need to be done. But we will see, i hope to have the engine in the car by next weekend and running the week after that but i guess we will see. This time around i will be using the complete kit from mazworx so install should be a breeze. Hoping this time we can push this fuc@ker over 300whp.
Also the car is completly different too , it is now widebody with a 6 point tigwelded roll cage and kouki front end, different color too. Ill be posting more pics in the days to come as im in cancun mexico now on vacation lol. Stay tuned
Carl H
lol, back for more eh.i've finally got my car running now its at the point where i need to fab headers...once thats done its pwnzeration time.
gs14racer
Yea back for more, this time for good i think.
Well back from vacation and this is where the car sits, ill hopefully have pics of the VH up later this week.
after i took the original VH out this is what my engine bay looked like
Stitch welded the whole front end
Stripped the interoir out, cut the hump on the floor and welded mounts for a momo fixed seat
Anyway, after that i removed all the windows , and rest of stuff. Primed and painted the interior with 3 coats of Dupont Chromabase and 4 coats of dupont chroma clear in mercedes indium grey metallic. Its like a gunmetal with gold metallic.
Then i cut and re welded the front wheel houses for more clearance with the 275s up front, they shouldnt rub any more
then painted the engine bay, again dupont primer, basecoat and 4 coats of clear.
More pics to come
Carl H
nice, gotta love spraying outdoors...def wont yeild a showcar finish but hey its just the engine bay.
T45
I am in love with the tire/rim combo. Imma give you a ring so I can come over and make sweet sweet love to them.
midnightsliding
im not liken that cage.
gs14racer
whats wrong with it ?
Mettler
Man you're productive Jerry! When you work on your car, are you rushing around fast as?
tmorgan4
Glad to see you back on here!
Carl H
its a mazworx cage, i highly doubt they'd half *** it.
Clifton
Car: 73' 240Z/7MGTE 71 240Z/L28ET
It has alot of rear bars but nothing in front
Carl H
perhaps thats what he wanted?more of a roll bar than a full cage?
gs14racer
Sorry i misuse cage alot its a 6 point roll bar, not cage.
midnightsliding
well im sure that they did not half *** it im not doubting their work. just a few things i dont like about it even though its just a roll bar1) the 2 piece diagonal bar2)the way its is concaved dose not help for strength during roll over.3) the placement of the diagonal, its welded near the weakest point on the hoop.
but its tig welded so thats b*dass and strong and saves weight but i still love your car! keep it up gives me hope.
gs14racer
Fresh off the back of my truck
Incredibly clean
Popped of the valve cover, the old man wasnt lying about regular oil changes
transmission is already at mazworx, should have it back by tommorow.
tmorgan4
This engine looks a lot better than the last ones. Are you going rear sump this time? I need to get some pictures of my oil pan I built.
Hope to see some progress soon since you always work fast. Glad to see you back around here!
gs14racer
Thanks good to be back lol. Front sump is the only way to go unfortunatly. I dont think it was the original problem anyway.
The motor should be running this weekend, im trying out the mazworx kit this time so everything should be plug and play.
gs14racer
some one left a present on my doorstep
Big props to mazworx for putting together such a nice and complete kit ,
Return to “VH45DE / VK45DE / VK56DE Forum”
