zehnder »
https://forums.nicoclub.com/zehnder-u71736.html
Tue Sep 18, 2007 7:39 am
I ditto your request.I`m trying to wire up my vh45 into a dodge dakota.When I turn on the ignition,I have the relayed power to the fuel pump and controller working off of the ecu ok,I`m getting gas to the engine.I have relayed power to the coils too.The engine cranks,I`m getting power at the coils,injectors.The damn thing won`t start.I do have one bad injector though engine ran ok before I started the swap.The only thing that I can think of is that ecu Ignition signal,Start signal and how I am suppling the power to the ecu is not correct. QUESTIONS: ecu pins 1,2,3,11,12,13,14,15 are ignition signal wires where do they lead?Pin 43, Start Signal,How did you hook yours?Pin 45, Ignition Switch. Diagram shows it connecting up at fuel pump relay circuit between relay and ignition switch.That works OK but when Key is turned off, ecu won`t power down for me.Pins 48,49,58,59 look like power supply to ecu.How did you wire yours?Like injectors and coils, that have both 12V power and ecu pin out wires connected to them,are there any other engine components that need 12V power in addition to the pin out wires? This is an awful long post and maybe it is in the wrong place, but you mentioned needing wiring specifics from GS Racer and maybe a lot of other people could benefit from a more detailed account so as someone on this site said to not "Re-invent The Wheel"
