Yes, with some washers instead of the plastic spacers typically found between the rails and the runners.Jeff Taylor wrote:Great to hear. Will the series 2 fuel rail bolt to any VH45 ?
If you read all of Jerry's (gs14racer) threads, you would realize that what he is currently using is much better than any boost computer from Stillen or JWT.Loch Ness wrote:have Stillen make u a Vh45de boost computer........problem solved......they have done it once before
Is this a pain in the a** to do?SuperHatch wrote:Jerry relocated his alternator to the AC position when he installed his motor. He did this so he wouldn't need to notch his framerail.
gs14racer wrote:question for you boost guys, what spark plugs are you running 1 or 2 steps colder? also what plug gap, i was thinking around .30?
I ordered a larger supercharger pulley as mine gave 9 psi at 6500rpm which would only get worse by 7000rpm, the one i ordered should give me 6-7 psi at 7000rpm.
