Postby
T04GTR »
https://forums.nicoclub.com/t04gtr-u180385.htmlThu Mar 14, 2019 3:48 am
Hello! I've been doing some homework, and I'm a little alarmed at how tight Nissan specs the oil clearances. Less the 1 thou on the mains, and the same for the big ends. How do these things live with abuse??? The main tunnel can't grow too much with heat?? Big ends is pretty run of the mill econobox specs.
I've built many high power 6 cyl engines, rb,2j and my VQ, all over 1000 to the wheels. And they all pretty much run around 3.5 on the mains and 2.5 on the big ends, and have great bearing life.
Is there a preferred "spec" that a built VH or VK is adjusted to? Again, over 1000hp, and 8-9k rpm, etc etc.
Dave.
Reason:TYPO
Th same way a F1 engine deals with abuse. Closer tolerances, more precise machining, better balancing.
It's not a 60's SBC.
Good point, I'd tend to agree, only issue is the VK45 in some applications is known for throwing poor UOA and bottom end wear numbers. And it doesn't even seem uncommon that some escalate to rod knock! Mine did..
