datsun5ten »
https://forums.nicoclub.com/datsun5ten-u23873.html
Sun Jul 05, 2009 3:22 pm
My vg30e has around 200k on it and was smokin a bit., so i have her torn down right now for a rebuild- After the machine shop does there thing it will still only be about a 3.1L.. I have been wanting to pick up a vg33e and just do a rebuild on that to get around 3.4L. Ive searched on the fourms, z31, 510 realm, ect, and havent found a straight answer. and i dont want to go source a vg33e if I cant make my parts work. so this is where Im at.
Carbed vg30e- using TBI intake manifold- ( not sure if the vg30e intake/water ports on the heads are the same as on the vg30e heads. I am running a electric fan with just a altinator off the crank so im sure i can make my crank pully work,- and I have a different oil pan, but im assuimg the oil pickup is the same as the vg30e so that should be a problem-
So if any one has some straight foraward info then shoot! Im waiting to order a rebuild kit..or go pick up a high millage vg33e and go that route- THANKS!!!!
