NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Fri Jul 17, 2015 11:32 am
You can swap everything from the Auto into the NA but not vice versa. You will have to grind out the inside of the bell housing to fit the TT FW/clutch and you can run the ECU from an auto but I believe you will either get a CEL for the trans or you may have to jump a couple wires, i'm not entirely sure there, try looking through the everything you need to know sticky and more specifically the Z1 NA to TT swap guide.
