RT »
https://forums.nicoclub.com/rt-u97343.html
Sun May 24, 2009 5:07 am
200 lbs more is nothing when doubling power and almost tripling torque. Yes V8 is heavier, but the HP and Torque increase more than offsets the weight, and again cost and reliability are way better with small block V8 at 300-350 hp than a VG30 built to even get close to that. A small block V8 can be made at 300-350 hp for much less and be more reliable than a v6 punched out, turbo charged or supercharged to get to the same HP. a 350 chevy engine with 350hp 325 ft lbs of torque is not even straining the engine design at all. to get that from a vg30 you are pushing it to the limits and will cost a fortune to get it there. A normally aspirated motor will out last the same motor with turbo or supercharger, as you are not pushing it hard. no replacement for displacement, all things being equal no way any v6 out does equal V8 in any state of tune. AQ engine is just a air pump the more air in the more power out. to get the same air in and power out of a smaller engine requires pushing the motor harder.
