VG30 Cold start / low idle issue
Discuss topics related to the VG and VE series engines.
tuttebenne
Car: 87 Nissan Maxima
I have an '87 Maxima that doesn't seem to act correctly on start up. Shouldn't it do a fast idle for a minute or so after first starting? Mine will start but run at very low rpm (sometimes stall) for a minute or so. Once it gets through the warm up period the idle comes up 150 - 200 rpm and it has much better throttle response. I just replaced a piston and rod, and had both heads done as a result of a Timing Belt tensioner failure. I can't find any vacuum leaks and was wondering what a more experienced person would recommend.
Thanks, Andy
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
You might try cleaning out the idle air control valve. That is most likely causing your idle problems.
Return to “VG30 / VE30 Forum”
