I have always found that my mpg numbers were suspect, if not to wind conditions (tail and head wind) then to the fact that in all the cars I've ever owned, the Versa is the only one that is so difficult to fill to the same level each time.Add to that, a variety of different gas brands out there on the long trips we make each year, and the peculiar characteristics of the CVT drivetrain, make consistent MPG numbers hard to attain.
So, rather than give up on my Versa MPG project , there is one last weapon to try, to finally get some real-time numbers, a Scanguage.
This unit plugs into and gets it's data from the ECM (on-board computer that controls the engine). What is nice about these devices is that they give you instantaneous mileage readouts as well as trip computations, and are said to be accurate to within 5/100 of a gallon. This will identify all the variables that occur, that can't be accounted for when you just 'do the numbers' at the end of a typical MPG calcualation. It will also instantly verify any changes that I make to get better MPG's, like checking different gas brands and to find the octane rating the Versa runs best on. (I have b een told by my Nissan dealershiop to try going up to a 'mid grade' gas) The Scangauge will tell me if I'm wasting money on that project right away.
I contacted the ScanGauge dealer for mine and he said that if anyone else from the Versa Forum wanted to order, he would discount the unit by $5.00. You just need to include this information with your order..."ScanGauge II Versa forum discount". his order link and a lot of interesting general info on getting better MPG's is at this link.
http://www.pureenergysystems.com/store/ScanGauge/
I am going to cut a hole for the wire inside that plastic box above the radio, feed it down to the OBD ll connection by the steering wheel, and keep the Scangauge in there...with the door closed to cover it when it's not being used.
Modified by longo at 4:28 PM 3/8/2008
