Versa Driver Side Exterior Door Key Lock Bezel
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
doug1973
Car: 2008 Nissan Versa Sedan
I have a 2008 Nissan Versa Sedan and the bezel which surrounds the key lock and holds the lock/unlock button (we have the inteligent key system) broke. The small tabs that hold it in place mush have broken off. After some Internet research, I believe the part number is 80644-ZW52B. A bezel for a non-inteligent key system prices at between $11.00 and $17.00. My unit,which looks the same except it has another hole for the lock/unlock button, was quoted at costing over $100.00 at the local dealership. Online I located prices from about $85.00 to $90.00+. This small piece is made of pot metal and is about 2 inches long, by about 1 inch wide and about 1/2 tall. Surely it can't price over $10.00 or $15.00?? Has anyone else had the same problem and come up with a realistic solution. Does anyone know if the button and all the electronics that make it work are included in the price of this unit? My button still works, I only need the little bezel cover. Thanks.
Return to “Versa Technical Discussions”
