Versa Audio system
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
k3vin15753
Car: Versa 07
Jeep patriot 08
Any 1 know how to remove the Audio system from a 2007 Versa. I want to get a new Receiver in there but dont know how to take out the FM/AM/CD player out of the dashboard. Help plz dont really know what i should be doing and dont want to mess up my car lol.
Kolk1
Car: 2007 Nissan Versa
The center vent area above the radio has to be lifted up, and kinda pulled towards you at the same time. That will expose 2 scews. With those removed, the whole area around the radio will pop out towards you.
Remember, DO NOT turn on the key, while you have the Air bag light removed. Its the sensor on the right side of the radio. If you do, your stuck with a warning light until the dealer removes it for you. its like a $100 fix.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Here's a guide. http://www.nicoclub.com/articles.php?id=227206
And if you still unplug the airbag light then here's how to fix that:
As long as the airbag hasn't ACTUALLY been depolyed, this will reset the system.1.Turn the key from off to on.2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key to acc instantly.3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)4. Repeat steps 1-3 two more times until you have done the cycle three times.5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
Kolk1
Sweet, its been a long time since ive been on this board, didnt know they found a at home remedy for the sensor.
k3vin15753
Car: Versa 07
Jeep patriot 08
Thx the guide really helped but just wondering i want to install this
http://www.newegg.com/Product/...17190
but im pretty sure it wont fix in the same way since the Nissan Audio system is so much bigger. Would i need to buy something like this in order to make it fit?
http://cgi.ebay.com/2007-NISSA...sting
Kolk1
Yes, since its a single Din radio, and factory is a double din, you will need a Dash kit, also a wiring harness and a antenna adapter.
Shad0wXCalibur
I would get the double-din version of that deck. It looks better, less cramped, and there's a very good seller on ebay named barneyselectronics who sells it for around $260 which is where I got it from. Single dins in that big of a space look tacky to me.
Return to “Versa Technical Discussions”
