Versa 2007 clutch pedal linkage
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Infinitiex35versa
Car: Nissan versa and Infiniti ex35
I am a new versa owner but have been an owner of nissans and Infiniti cars since 2000. Did anybody have issues with the flimsy plastic clutch pedal linkage on the Versa? Mine is a 2007 6speed (pre-owned) and the clutch pedal linkage is making this clicking noise when pressed and this more often than not recently. I am afraid it will pop off and leave me stranded with no clutch. I cannot believe how cheaply made this critical part seems to be. Any ideas on a possible fix or more secure replacement part would be greatly appreciated. Thank you!
zajogee
I have the same vehcile branded Nissan Tiida in south africa. Place a hose clamp around the clip. Dont tighten too hard as this could futher crack the clip.
Infinitiex35versa
Thanks for the reply. It is hard to believe this has not caused problems to other Versa owners and the company has not addressed the issue. I will try your fix but still afraid that if the linkage cracks, I am screwed.
Return to “Versa Technical Discussions”
