I’m guessing this is why mine are leaking. I may have put too much sealant in the groove. I put a little pretty much at every bolt hole.
Be careful, only to tighten the cover bolts to the wimpy torque specified. Shoulder bolts on the plastic covers and stand-off spacers in the grommets on the aluminum covers allow the covers just enough compression on the gasket to seal it. Overtightening does nothing to change this because the cover face and the head do not actually flush up to each other completely. The shoulder bolts and stand-offs prevent that. Overtightening will only crush the stand-offs for aluminum covers and distort the cover at the mounting holes and possibly break these small M6 bolts or strip out the aluminum threads in the head for either type of fastener. If the sealant you put in the cover gasket groove had time to cure, even a little bit, before you installed the cover, that will prevent the gasket from seating properly. Be sure the head faces are cleaned up to remove all hardened oil and varnish residue. Even a thin film of hardened residue in various spots will cause a leak from a new gasket even if everything else was done right. With surgical precision, a razor blade can be used to remove this residue but beware not to gouge the head face and create a leak pathway out of the engine.
Very helpful details. And you called it… after finding the leak I think crushed the stand offs and now I probably have to buy new ones. Fortunately nothing has stripped out yet. I will be careful next time.mdmellott wrote: ↑Sat Jul 02, 2022 9:51 pmBe careful, only to tighten the cover bolts to the wimpy torque specified… Overtightening will only crush the stand-offs for aluminum covers and distort the cover at the mounting holes and possibly break these small M6 bolts or strip out the aluminum threads in the head… If the sealant you put in the cover gasket groove had time to cure, even a little bit, before you installed the cover, that will prevent the gasket from seating properly.
