valentine one hardwire?
zigzagzig
Anyone here with a valentine one have it hardwired to the fusebox? I'm going to try and find our fusebox so I can splice the wiring into the windshield wiper fuse.
The only thing I have a question about is how to hide the wiring down the a-pillar.
Anyone with insight into this?
Faja
Car: 2009 Nissan Sentra
You should just be able to pull the A pillar right off!!
Supercourse
Car: 2007 Nissan Sentra
2004 BMW X3
You will be able to tuck the ignition-switched supply wire inside the A-pillar without pulling it off.
The trim isn't a snug fit against the windshield.
The 90 deg. bend at the top might be hard to conceal though.
Fairly simple to snake the wire from the top of the dash down to the fuse box.
Can't remember exactly how I did it, but it took well under an hour.
Handling those mini fuses takes some dexterity.
zigzagzig
Oof. I was hoping it wouldn't take more than 10-15 min, hehe. That's how long it took in my previous car.
Did you just take the wire and basically put it inside the fuse slot and then shove the fuse inside?
Also, do you use any sort of custom V1 mount or anything? The suction cup mount is too invasive and the sunvisor mount makes me unable to use the visor obviously.
Thanks for the helpful info.
