vacuum lines and sensor help!!
Jerrybrown5081
Car: 96 300zx tt
Ok, I have a 1996 300zx TT. Was replacing the intercooler piping and found a vacuum line coming off some kind of sensor, can't figure out where the hell that thing went to. Also found some other sensor thing which looks like it has connections for two different lines with nothing on it. Me, in my infinite wisdom, forgot to take pictures of the car before doing this work. And where as I can definitely do all my own installs and such, I'm no mechanic and am not sure what the sensors are. If I could get some help identifying them and figuring out where this damn vacuum line needs to run so I can put her back together, that'd be awesome! Need to finish doing my damn clutch by the end of this weekend as well and I don't have the time to be messing around with this haha.
Heres the location of both sensors that vacuum line can attach too.
Okay, heres the first sensor. This one had a vacuum line already attached to it, couldn't figure out what it is or where the vacuum line goes to. Gold one, not the other one
[img]blob:https://www.flickr.com/825aacd3-60c7-4d ... 1d27399629[/img]
And finally, the second sensor that I randomly discovered while searching for whatever the first sensors vacuum line connects to.... Was thinking that was where it connects, but theres also two ports on it so i have no clue.
Any help would be much appreciated!!!! thanks!
