Vacuum Gauge install questions
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
DJ_SLapo
I'm starting a gauge project. I been looking around on the form with no answer. If I could get help. I can make write up to answer all these questions plus the write up.
I had a few questions about gauge install.
1) A good source to tap to read Vacuum.
Using PCV off intake mani on the left
2) A good place to run wire(s) from engine bay to cabin.
Using locations most people run AMP wiring
3) A places to tap for power. Looking for a trigger for running lights
Using factory Accessory Service Connector (Part # 999Q9 AY000)
Using driver side connector port
Taping Pin #:
1 for power
3 For ACC trigger
Car:
Factory 2014 Versa Sedan
Gauge:
Depo Racing Digital combo series 52mm
Once again, thank you
Any questions and comments are welcome
Return to “Versa Technical Discussions”
