vacuum at idle?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
just wanted to know what kind of vacuum (in hg) everyone was getting. i think mine used to be higher than it reads now. i have a very suspicious t-connector between some vacuum lines that could be leaking oil (since my car still leaks/uses oil like crazy despite a full rebuild using very expensive parts)
and yes! my car does leak a crapload of oil out the intake and crankcase breathers despite brand new rings! wheee!
- tim
edit: you guys need to see these brakes i got for my car. they are absolutely ridiculous to be perfectly honest. i dont think i have ever seen a s13 with anchors of this magnitude. the 13in rotors look like very large dinner plates, and the calipers are needlessly massive. to give you an idea, the pistons in the caliper are a little larger than a half-dollar, and the body is about 10in long. they will probably require a very large spacer and maybe fender flares to clear my little 17s. they WILL go on though, so wish me luck.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
I run anywhere from 17-20 of vacuum so I know I don't have a vacuum leak.
Modified by nnkfws333 at 3:33 PM 9/8/2005
float_6969
I run right about 19inches when it gets warmed up. Thats, for all practical purposes, a new motor. High compression too, but I don't think that would effect how much vac it pulls.
rico05
Car: 1992 RMS13 w/ CA18DET
19-22inHg depending on weather.
r34 gtr
im only getting about 15, sometimes as low as 10. im pretty sure it used to be around 20. ill definitely try and replace that t-connector sometime this week.
- tim
8ggalant
Car: nissan cefiro
i get 19-21...did u install cams...most guys i know w/ cams on ka/sr motors (and we'll see when i do mine on my ca...or u could just ask dee) vac seems to be around15-18...but as low as 10...havent seen that
r34 gtr
im pretty sure something is up vacuum wise...but it does have cams in it. not sure they really do anything though.
- tim
float_6969
The cams open and close the valves Tim. That's what they're there for....
nnkfws333
float_6969 wrote:The cams open and close the valves Tim. That's what they're there for....
He is probably referring to if it actually puts out much hp or power with his mods from what I took it as.
