nismo1003 wrote:First of all, there are three things I need hook it up to the back of the intake manifold (boost source to read the boost) . FMU , Boost gauge and Boost gauge. should I run like this
put two Nipple side by side?
http://community.webshots.com/...hPjBr
or put it like this so I can just use 2 nipplehttp://community.webshots.com/...vWMkB
I don't think it matters. Either way should be fine since there is almost no airflow on those lines, just pressure.Quote » second, I dont know if i need to plug this in?(or I shold get rid of the Y and make that one line only.
http://community.webshots.com/...UkkgRthe line that I am holding?that line orgnially from the intake hose (2 big hoses , one small hose) and to here:
http://community.webshots.com/...OcqPz I believe this small hose run back to the EGR vavle.
thrid - is it not ok to put all the source line too close? [/quote]
Since I can't really tell which lines you are refering to on the third and fourth pictures (where they come from), I'm gonna tell you this. Looking at the TB from above there are 4 lines beneath it.
1 - From control solenoid to carbon canister (plug if not using carbon canister)2 - Manifold to PAIR valve (I used this one for my BOV valve signal since the PAIR valve is gone)3 - To EGR control solenoid (I routed this to before the compressor)4 - From Carbon Canister to Manifold (another source of manifold pressure, or you can plug it)
Hope this helps. Of course the bigger hose on the right of those goes to the idle relays.
