Infiniti V8 Oil Filter part numbers and aftermarket substitutes
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
EdBwoy
V8 folk, some info for you. It might come in handy.
This is for the oil filter used in Infiniti V8 vehicles. The part number is compatible with some Nissan models such as the 4th gen Maxima, the R35 GTR etc... but this info is for the V8s in particular; you my friends, are the neglected group.
Nissan OEM oil filter.
Old part numbers.
15208-31U00,
15208-31U01,
15208-31U0A,
15208-31U0B,
Superseded to 15208-9E01A
This applies to the following models and their engines:
M Series sedan - VK45DE, VK56VD
  • 2003-2004 M45
  • 2006-2010 M45
  • 2011-2013 M56
  • 2014-2019 Q70 V8
Original Q series sedan - VH41DE, VK45DE
  • 1997-2001 Q45
  • 2002-2006 Q45
FX Crossover - VK45DE, VK50VE
  • 2003-2008 FX45
  • 2009-2013 FX50
  • 2014 QX70 V8
SUV - VK56DE, VK56VD
  • 2004-2013 QX56
  • 2014-2018 QX80
EdBwoy
Big thanks to the K&N Filter I bought that motivated me to do this.
You'll notice that some brands have more than 1 number listed as compatible. That's usually a matter of size/length IIRC. When in doubt, take the larger one. The Nissan OEM filter is approx 3-1/4" long.
The size matters when you refill the oil after an oil change, sort of. Remember to check your dipstick.
AC Delco
  • PF2057
  • 25014568
Baldwin
  • B1401
Bosch
  • 3323
  • 72179
Carquest
  • 84141
  • 85356
Castrol
  • CA1030
  • CAS7317
Chrysler
  • 5142416AA
  • 5142416AB
Ford
  • F12Z6731B
  • F23Z6731B
Fram
  • PH7317
  • PH5343
GM
  • 25014658
Hastings
  • LF240
K&N
  • HP-1010
Mobil 1
  • M1-110
Motorcraft
  • FL2007
Napa
  • 1356
  • 1357
Purolator
  • L14610
  • L14620
Royal Purple
  • 10-2867
Subaru
  • 15208AA15A
  • 15208KA000
WIX
  • 51356
  • 51357
EdBwoy
And a video
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
