rileyingraham »
https://forums.nicoclub.com/rileyingraham-u313597.html
Thu Jan 23, 2025 10:10 am
Hey guys, got an 07 G35 (V36) Sedan 6MT with a very specific problem that I haven't been able to find anywhere else on the forums - also, apologies in advance if this is the wrong sub-forum to post this in.
Here's a little history on the car just in case it helps:
I bought it not running and it needed an ECM. Got the new ECM, and replaced the BCM too just in case, had everything reprogrammed and replaced the fuel pump. The car runs fine now, but could use spark plugs. It's going to be part drift car so I unplugged the YAW sensor and brake switch sensor. There's signs that it has been hit in the front at least twice but only hard enough to just push the corners of the bash bar in a little. From the looks of it, the radiator and fan shroud have been removed before (lines are in weird places and just don't sit right) but there didn't look to be anything unplugged in the front.
Bottom line, the fans don't work at all. The fans don't come on when I turn my AC system on (though I don't have every part of it, the guy said "it needs a couple of lines and something that goes behind the battery") and they don't come on when the car gets hot. I can leave the car at idle and move it around a bit and the temps are fine but doing anything else will cause the temps to spike. I've replaced the PMW fuse (or PWM, can't remember the exact name) and the fan control module and still nothing. I was able to put direct power to it from the purple wire leading into the fan control module and the fans came on but other than direct power I can't get them to even move. I've even replaced my coolant temp sensor just in case something was wonky with it but that still didn't change anything.
If literally nothing else works, probably going to just wire them to a switch and manually turn them on after it gets to operating temps to save the hassle of tracking down whatever could be causing this. I'd rather not do that though because I want this to also be a nice street car too and I'd rather have everything work the way it should.
Any advice is appreciated!
