V-Belt Crank to Waterpump/ Alternator
Pumaking
Alright guys I seem to have a little problem. I was gonna change my V-Belt for the crank to waterpump/Alternator. I tried using a pulsar belt and it was to small. I was wondering what other kind can I use. Is it possible to use a 1985 Nissan 200sx CA18ET belt for crank to waterpump/alternator.
sideways danny
Car: s13, CA18DET
take a look at the s12 silvia belts, I think a CA18et or CA20 belt will fit
biosehnsucht
Belt sizes, see the details column.
Armed with those belt codes (forget if they're bando or gates or whatever, any parts store can look it up from that tho) you should be set.
Pumaking
your a saint bio.
sdtouge
Car: 1990 240sx coupe
is it so hard to just get a string and take it to the store like i told you twice lol?
Pumaking
yes it is b/c I dont have string
float_6969
I've done the string trick and still had quite a problem with it. The alt/water belt wasn't a big deal. The PS belt is the problem. I actually still haven't found one the right size. I had to reuse the one one that came with the clip. If anybody find one that works, lemme know...
sdtouge
i have one that works, i think i left the box from it in my tool box ill check later and let you know.
