using live edit
1SlowCA18DET
on i plan on using live edit and im wanting to know if i get a romulator model 1 if there any way that i can data log with it? Also with live edit and that romulator i will be able to change the settings right away correct?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Yes, you need model one of the romulator. No, there is no logging feature. And yes, you can make changes on the fly with it. What you want to do, is make all the changes while running a wideband. Once you get everything where it needs to be, save the .bin file and burn it to an eprom. Then you should be good to go.
originalsin
romulators are liek $180 correct?
c-rad
originalsin wrote:romulators are liek $180 correct?
The one you NEED to get is the model 1 from http://www.xtronics.com
1SlowCA18DET
is there any kind of launch controll/ 2 step feature wuth live edit?
c-rad
1SlowCA18DET wrote:is there any kind of launch controll/ 2 step feature wuth live edit?
No... its simply fuel and timing. Only other things you can do is remove the speed limiter, raise the rev limiter, and adjust for different MAFs.
1SlowCA18DET
ok thanks for all of your help, just ordered mine. Hopefully i wont blow anythign up
tonis56
Car: 04 Titan Crewcab
Is there a place/mirror that we can download this from? I cant seem to get a good copy of this program. Also, to anyone who has used this, do the 29c256 chips work for the SR ecu??
tony-
tonis56
well, i downloaded it. And I keep getting the run time errors that I have always gotten with this program. In the readme file it says
**** IMPORTANT ****
Until I fix some more things you MUST installthis software into the default directory...
c:\live edit
if you do not do this - the software will NOTwork correctly....
Im assuming that this is done when you install it. So when I go to the program and click on certain things it closes the program. Any input??
tony-
