NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Mon Sep 05, 2005 5:28 pm
we ran it because we don't have a CA maf. Its supposedly exactly the same specifications which is why you can just swap the two mafs without an SAFC to control it. According to some it has a slightly higher upper limit, but it wouldn't be worth swapping out a working CA maf for a SOHC KA one from a performance standpoint. The gains will be negligible. And in fact unless you're maxing out your current maf set up, even running a big z32 maf won't "make" more power.
Sean
