pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Thu Sep 22, 2005 2:14 pm
The ca18de clutch and pressure plate will work fine, the clutch itself is about 1/2 inch smaller in diameter, but if you are gonna be running stock boost that should be good, I am using a Nissan Stanza 1992 clutch and pressure plate, they will bolt right on.
I also used on my buddys car a ka24E clutch.
Centre force clutch is a waste of money, few years back when I installed my ca18det engine, I bought a stageII dual friction clutch from them $500 dollars (9 years ago), and it slipped when ever it reached 9psi.I then bought a Stage II full feramic BULLY CLUTCH locally as the main manufacturing for them is in Ottawa, I had it in for 5 years now and running 18psi on T28 and it doesn't even slip.
PULSAR GTRRafi
