Use Nav While Car Is Moving
Gposse
Car: 08' Altima Coupe 3.5se
Is there any way or setting on the nav system in the tech package to allow you to set routes and do the additional disabled features while the car is moving> I know it is for safety but it would be nice if I have a passenger in my car and she could set a destination or modify settings in the nav while the car is moving, I hate having to pull over to the side of the road.
glozaeta
Car: 2007 Altima 3.5SE
Gposse
did some research. I guess there's no easy way without splicing wires
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Give it time... If people were able to get the hacks for the avic's and such, it's only a matter of time before they figure out how to hack the Bose Navi. But yeah it does suck NOT being able manipulate the Navi while you're driving
Importroller
Car: G35 and 07 Altima 3.5 6spd
Search Nissanclub.com in the 07-08 section. There is a write up by GTcompscientist (I think thats his full SN) on how to do it in the sedan. Only way is to splice with a toggle switch.
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
What do you mean by "splice with a toggle"?
Importroller
http://www.nissanclub.com/foru....html
This is the thread for the sedans. Not sure if it works on the coupes, but you can try
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Sweet write up! Thanks for the link. I did have a questions though. He cut the wire from pin#8, It looks like he ran a piece of green wire from that to the toggle switch. Where does the other green wire come into play? I know it connects to the other blade of the switch but where does that get attach to?..the other end of the wire that attaches to the connector? Sorry if I'm being dense on this but the pictures were not clear during the splicing part so I just want to make sure I understand fully of what he's doing.
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
I dunno if that will be enough. I can change any option at a stop light while not moving but in drive, foot on the break. as soon as the GPS sensor detects that i'm moving again, the options become grayed out. Makes me think that the feature is software related and not Park/Parking brake activated
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
I have to agree, I have a stick, but once the gps sense me not moving I can acess all features, doesn;t matter if I am in nuetral or any gear for that matter...seems like software
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
LinkNuc wrote:I have to agree, I have a stick, but once the gps sense me not moving I can acess all features, doesn;t matter if I am in nuetral or any gear for that matter...seems like software
But something has to trigger that software to grey options out once the vehicle is moving. Question is what?
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
hey guys, its def worth a try. yes, the software can detect when the vehicle is moving, but it can be tricked. the hack with the avic D3 takes advantage of loopholes in the software. before folks figured it out, they used to use the same method employed in this write up. but a whole team of techies worked on solving the hack in the avic
Importroller
I use an aftermarket Pioneer N2, so my hack is different than yours. But the switch basically cuts the signal to the unit when you want to access it. I think when the switch is turned off (not allowing contact) disables the signal to the computer so it thinks you are stopped, even though you arent
LinkNuc
Ah yes so the toggle switch mod should work...cool
rjdmmfl1
Importroller wrote:I use an aftermarket Pioneer N2, so my hack is different than yours. But the switch basically cuts the signal to the unit when you want to access it. I think when the switch is turned off (not allowing contact) disables the signal to the computer so it thinks you are stopped, even though you arent
Haha, no toggle switch needed on the D3, no headlight flashing or any of that, just switch the mute wire on the harness, ground it, ground the parking brake wire, and go...
There has got to be a way to switch ISO files in the factory nav unit, but again, it'll tack some hacking gurus to figure it out the way they figured it out on the Z2, and I doubt anyone is putting that kind of effort into hacking the factory software for the Nissan Nav
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
rjdmmfl1 wrote:There has got to be a way to switch ISO files in the factory nav unit, but again, it'll tack some hacking gurus to figure it out the way they figured it out on the Z2, and I doubt anyone is putting that kind of effort into hacking the factory software for the Nissan Nav
Good Point
Importroller
on the N2 all you do is pull back the warranty sticker on the bottom, use a circuit writer pen to connect the R32 pins located underneath, and ground the parking break wire and you are Hacked
