TDot wrote: ↑Tue Dec 25, 2018 7:24 am
@steve_c what's the difference between flush and bleed? Is it just a matter of pressure pushing out all valves at the same time with flush?
Bleeding usually means releasing fluid at the calipers to be sure no air is trapped, benificial because it removes the worst of your brake fluid. Flushing is similar, only you keep bleeding until you have removed & replaced 100% of your fluid. (from master cylinder to brake calipers).
My criteria is (
others may have their own opinion):
I look at the master cylinder for fluid condition:
Fresh Fluid is clear
Fairly fresh/Mildly contaminated has yellowish tint
Moderate contamination has dark yellow/brownish tint (time to flush in my opinion)
Severe contamination is dark drown/black tint
What color is your brake fluid? (you can see it through the plastic reservoir)
