Usually if your brake light goes on up a hill, you are low on brake fluid and your reservior sensor can see it.nissanpark wrote:My nissan sentra 2000 GXE battery and brake turned on month ago, which only happened when the car was up the incline especially when speed up, when down the incline or on the flat road, the light turned off. I took it cheked by nissan dealer, the alternator and the battery is good, the brake fluid is full, I also changed the drive belts, it is no use, they can not find the problem. in recent days it turned on more often than before. Does anyone meet the same problem and can help me fix the problem?
