upgradeing the throttle body
pae9132
Car: Modified 03 V35
I did a search in g35/37 forum as well as the mechanic forum but nothing was about upgradeing. I just read an article about the "Endless Z" using a VK45 throttle body. Would this work on a 2003 G35? I already have an aftermarket plenum and intake w/ztube. Would this be too much air? The car is N/A. Thanks.
Q45tech
Important to understand the PHYSICS of automobile engines.
Why would a manufacturer/engineer intentionally use an undersized TB.
You can measure the air pressure drop across the TB to determine the pressure loss........................generally it is less than 5" H2O or 1/6 of a psi which leaves 1/6 x 6.8% or 1.13% of the peak power on the table.
On a 270HP engine that is <3 HP lost....................however a significantly larger one might only gain 1, 1.25, maybe 1.5 HP.
The larger the diameter the less fine response you get so the engine is more difficult to idle and cruise at low rpms.
Remember the Earth's giant supercharger supplies a constant pressure to the system ~~~14.7 psi.........................measure your WOT plenum pressure to see how much of this is lost.
pae9132
thanks. I'll just stay with the stock t/b
