roe_wedge wrote:First off you guys are the biggest help on any of these forums. Seems like the CA guys are a tight group . It doesnt seem that much to get the CA beating the SR... how about the torque though? is it good at the low end side of things?
Mod for mod, the SR will make more torque. Theres no replacement for displacement. Also, the displacement is mostly upped in stroke (main torque maker) 86mm vs. 83.6mm.
Quote »Right now my big noob decision is between the RB or the CA. Both have their advantages and disadvantages. Some people tell me that the CA is basically the same as a RB20 just with two less cylinders.. (you know what i mean!) Is that true?[/quote]A CA18DET is more like a RB26 (or 27) with two less cylinders, displacement wise . A RB20 as a 4cyl would be only 1.33L . Architecturally/Design wise they are very similar. Except all that the CA has a longer stroke than every RB but the aussie-only RB30. Quote »How much does the CA18DET weigh?
and if you know... how much does the RB20DET weigh? i heard it was just 10 lbs more then the KA. Just for quick comparison. [/quote]CA18DET: w/ 5 speed - 390lbs or soRB20DET: Can't tell ya, but..RB25DET w/ trans, so should weigh similar: 700lbs or so.
And for comparison, a SR20DET weights about 490 w/ 5 speed.
Now I've also heard the RB20DET is atleast 100lbs more than a SR20DET, so safely we can say its 650lbs +- 50lbs
