vikesfankevin86 wrote:I have heard the dual air intake is best when you have upgraded turbos and not before. My goals are to push about 20-21 psi so I would like to upgrade trubos, intercooler, dual air intake, blowoff valves, fuel injectors, possibly cams. Whatever I need to make it safe. Next summer I will have about 7,500 to spend on it.
A Dual MAF, Dual POP (intake) will benefit any TTZ. Not only does it add power, it shifts your power curve toward the left, giving you a bigger power band.
BOVs are not necessary. Really. They're just for fancy sounds.
Silicone hoses replace cracked and leak prone OEM hoses, and they reduce the likely hood of boost leaks, but don't really add power.
Intercoolers are a must, so are upgraded injectors.
If you're really looking at a $7500 budget, I'd include the bomb-a** SZ 3" expansion downpipes, the MSP manifolds and a set of either the JWT Sport 530 turbos or Z1 GT600 turbos. Cams are fine, but porting the OEM heads and using OEM TT camshafts with ported heads give great street response.
Look into methanol/water injection. Snow performance is one brand I know of.
For Z parts, here are two great sites:
http://www.specialtyz.com
http://www.importpartspro.com
I've run JWT, RPS and Southbend clutches, all were excellent. The RPS flywheel is the best available for our cars. Guess high on your estimated torque number and be safe. The JWT Severe Duty would work, RPS Max Street (I recommend street over 6-puck unless you drag race often, and in that case, the OEM flywheel is better for dragging). There are more options from Southbend as well. I'm currently running a Southbend Stage 5 Ferramic and I love it. Contact member Spddracer
[email protected] for more info.
Modified by BigTDogg (MA) at 9:27 PM 3/17/2010
