kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Mon Oct 20, 2003 12:06 pm
I had posted a few weeks ago about an intermittent problem I had with missing either on starting the engine or within a few blocks. Initially it was intermittent, then it became constant. Replacing the #4 injector solved the problem. (the coils were OK and my mechanic replaced the plugs while he was there) Or it solved the problem for a while.
Within a few days, the problem recurred. This time replacing the #6 injector solved the problem. My mechanic thought the battery seemed to be the problem, and checked the alternator, which was charging at almost 17+ amps. He replaced the battery, the charging rate fell to under 16 amps, and I have not had a problem for 2 weeks now.
He mentioned something about the injectors in that year having only 4 Ohm resistance or something like that, leaving them susceptible to problems of frying. Does that sound reasonable to you gurus out there? If so, is there anything I can install to protect the injectors from frying again?
ThanksKen K
