So, to recap, I bought a seized up but otherwise straight 4x4. I'd talked about it before and thought I'd update the story and share the process of this project to those who give a rats flying something or another. So, like i said, it's seized up, bad. Can't break it loose jumping on a breaker bar. Pulled the motor all the way out, first timer, and put it on a stand. Flipped it over and took oil pan off. After a few days with MMO I got the crank to turn enough to be able to get a wrench on the rod bearing caps(they were hiding below). So, when taken all the way apart, the next step is machining. I'll need a soak, a bore, and who knows what else, right? QUESTIONS:1)What kind of money do you spend at a machine shop for this kind of situation? 2)On rod bearing caps, say I know what order they go in but forgot which side is right side up and they fit both ways. Am I screwed? The symbols on them seem to mean nothing and don't have arrows. 3)Anyone have an opinion on the quality of rock auto parts? Or ITM?
Thanks a pant load chet
