nismo4life11 wrote: You could always run the one you got with reducer couplers.
Like tom said go threw and make sure everything is clean (pretty sure thats not it though mine sat for 2 years before it was started again and it started first try lmao) but also check all your wiring could be a short or disconnected wire somewhere. Heres the FSM if you need it http://www.nicoclub.com/FSM/Sentra/1995_Sentra/Nismoaniak wrote:well we can hear the relay clicking when we turn the key,.. but the pump makes no noise whatsoever. so im not getting any fuel. i think it might be the fuel pump and ill double check the lines.
Nismoaniak wrote:I noticed the line was semi clogged by a orange goop type stuff.. i went to autozone bought a fuel filter and fuel line.. replaced those and when i turned the key.. still no start. ok so i decided to change my pump.. (which i had bought earlier that week) and as i pulled out the seat and finally got to the pump and tested the positve wire,.. i had 12 volts passing through there so i went further. pulled the pump itself out and tried turning it on then.. no start. i connected the new pump w/o submersing it in the tank and that pump turned on.. i decided to change the pump. LMAOmy friend snatches my old pump from my hand and bangs it on my table and tells me to cennect it then... sure enough it worked! it had just seized up. soooo the car started she lives!!!!
.. thanks guys.
Nice I love the old 240's definetly a sweet car if its done up right. As for the NEO you dont get half the pop for the price. You can get everything for a turbo for under $2k and I know because I'm gunna be turbo!!!! I'm at $940 and already got 99% of the stuff for the turbo all thats left is the 3" downpipe, exhaust and the walbro 255 pump so hopefully I'll be done in about a month or two and she'll be turbo'd.Nismoaniak wrote:lol ok well i doubt ill turbo my SE-R i want to buy an S-13 and swap a SR DET in that bish or an RB DET. for my B14 when i have a enough money saved up i would love to have a NEO VVL SR20 in my 200. and go all motor. unless i find a good deal on like an avenir or something then maybe id give into temptation and turbo the 200 haha. you gona go turbo after all?
jaja cayese guey! lol you wernt helping today! lol jk jkDMeN Z wrote:Get it done ese!
So that's why you asked me what you needed to boost. Made me think you were genuinely interested in adding snails to Se-Ra.Nismoaniak wrote:lol dude that is not in my budget range!!! lol i would most likely end up buying a det if anything haha. did you also buy low compression pistons? forged rods?
