pattsy »
https://forums.nicoclub.com/pattsy-u101663.html
Thu Jul 24, 2008 6:54 am
I have a 1997 Nissan Maxima that overheats when I have the air conditioning on "AUTO" and the fan position is on "high." The system is blowing out alot of cold air when it is on high but the water temperature will go all the way up to the point where I have to turn the A/C off. The car will sometimes overheat when the car is stopped at a light whenthe fan is on low. The cardoes not overheat at all when the A/C is off. The thermostat was replaced about 8 weeks ago with no change in this condition. Can anyone give me any suggestions?Thanks,
Pattsy
7/29/08:I checked the radiator fans, fuses and relays. All seem to be working fine, I confirmed this by running the engine in the driveway and putting the a/c on "auto". a/c started working and the fans started running. temp climbed to its normal range. ran for 10 minutes with no problems. Took the car on the high way. After about 10 minutes the temp started climbing. Turned off a/c and temp dropped back into normal range. no derbis on the radiator. Still trying to fiqure out what to do. Anyone have any other ideas?
Modified by pattsy at 4:22 PM 7/29/2008
