CoupeVQ35CVT »
https://forums.nicoclub.com/coupevq35cvt-u137499.html
Tue Dec 15, 2009 10:20 am
OK, I'll bite. I went the same kinda route with my Sentra 1.8.
Custom exhaust piping (2.25" vs stock 1.75") and aftermarket resonator (12" long) and aftermarket muffler (Flowmaster 40). It will, when cold, sound different than when it is hot. It does actually sound a little like a fart can type exhaust at times.
I USED to have an aftermarket header also, and that REALLY kicked up the raspy sound, almost embarrassing. I had to have the resonator installed just to muffle some of that drone inside the cabin and get rid of some of the raspy-ness.
Our 4-cyl engines are just prone to that kind of noise. However with that said, make sure your cats are not busted causing whatever this is. I had a Magnaflow cat installed when i had the ebay header on there, and after a year the honey comb had separated from the cat's walls and rolled around inside, sometimes blocking exhaust flow (yes that meant my car took 10 seconds to get to 40 mph). Now I'm not saying that is the problem you have but it is one possible issue.
I definitely recommend the resonator option too, it will get rid of any raspy sounds and quiet it a little bit. Good luck!
