I cant find my build thread on here.
random shot of wire harness plugged into the ac. Once I have my triple pressure canister situation and hose situation resolved. I'll worry about taking the system to an ac specialist to get charged.(obviously first worrying about registration/insurance/tags.)
I still have a lot of wires unanswered for. So I will go through the process of de-pinning them once I sort out the headlight wiring. Fan is wired up, A/C is wired up, relay's are wired up. Just need a relay for the headlights, or make sure E7 is not located on the interior (stock) fuse box.
spent most of the day charging my battery, not sure if my charger works properly or not since it doesn't read voltage out anymore. But judging from my trunk light coming on, and me being able to turn on my tail lights and city lamps. I think it's safe to say, we in da building.
And now, for an electrical systems test.
http://vimeo.com/3934295
I would like to add, I did not plug up the dimmer switch. That may be why the lights were not coming on the cluster, I'll have to double check that. It might also have something to do with the hazard switch, or that causes my turn signals not to work, cant recall.
Either way, I'm going to try and wrap up the wiring tomorrow and fire it up.
Then jump into the digital climate control.
Question for anyone that's done it before. How in the f*** do you mount it to your console, I don't see the holes matching up, at all. Guess I'll look at the faq/how to tomorrow.
And that's a wrap for today.
