turbonetics?
iNfamous240
I was just wondering if you guys would recomend getting a turbo from turbonetics.
huguetpj
Car: 93 KAT Coupe
Yes
s86d
Car: autocross, backroad racing, and working on 240's
be more specific. of course we would but the wrong size is worthless.
95_240sx
Car: My baby (car)
dont buy their deltagates.
Rick
Nathan
Could someone direct me to a link detailing someone who had a problem with a deltagate? I've SEARCHED high and low and heard nothing bad about them, I've taken mine apart and while not as pretty as a Tial looks like it's constructed just fine. The actual mechanism is pretty idiot proof and the machining is good so I fail to see what is wrong with them.
fiznat
Car: Grown up :(
shut up nathan. they're terrible, and that's it. quit making waves, I mean christ- do you LIVE FOR CONTROVERSY OR WHAT!?!? CHRIST!:burger:
Nathan
fiznat wrote:do you LIVE FOR CONTROVERSY OR WHAT!?!? CHRIST!
Oh you KNOW I do :)
95_240sx
Car: My baby (car)
I have seen one stick on a corrado turbo, and run 25psi on a stock engine and fuel system, doesnt work good.
Rick
95_240sx
Car: My baby (car)
And, cant we juyst dislike csomeones products for no reason? I mean, come on now, we dont need reasons.
Rick
Nathan
Hmmm, thats about the most I've heard bad about it right there. Any idea why it stuck open?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Radio: I have 11-32 in progress at NICO, Suspects are armed with keyboard and a fast internet connection proceed with caution.
11-32 = thread hijacking
s86d
wtf I wanna know also about the faulty/crappy deltagate
C-Kwik
I had one before swithing to Tial. The Deltagate was allowing boost creep regardless of how I adjusted it. The Tial is working very well.
Nathan
Well, once it stopped creeping would it hold steady? I'll be happy if it will just hold 17 or so psi and know somebody it's working quite well for...at around that level and higher.
GELLIS2586
Car: 2006 IS350 / previously 1997 240sx se pearl white
hey 95_240sx how much for the turbo and manifold.
SloS13
I gots da turbonetiks!!!!!
TurboDave
I have personnally witnessed a NEW Deltagate with a 10lb spring overboost to 22lbs. This car had a stand alone so it had the fuel and motor to handle it. I have also seen them break the shaft, diaprams don't last long, etc. The tial 38mm counter part is rock steady.
TurboDave
Nathan
Hmmm, well I have the fuel to back up whatever the turbo decides to do so I'll post a full review of it once I get everything running :)
klattr1
Car: GT42R powered S14/KA
dude,my friends fluctuates like crazy. They are inconsistent and are known to spike over time.They creep with the lower pressure springs.FMax ditched running the Deltagate cuz people were complaining about the Deltagate running like 12 psi-15 psi instead of the 8 psi set level.So they started issuing their kits with Tial wastegates. Quality is much better.Rumors are started for a reason though. Nobody is just making crap up. Why go with something that is fishy?I think Turbonetics has a newly designed wastegate now. Also FMax is under Turbonetics so they will prolly use the newly designed wastegate.I love my HKS standard. Great quality. No fluctuations.
d240t2
I had a deltagate on my old black turbo hatch. It worked great for 3 months...after that, it boosted what it wanted. Sometimes I got 5psi, sometimes 7, sometimes 8+ (when I'd let out so I didn't blow the engine on a basic fuel system). Its a piece of junk...and for $50 more, you can get a Tial wastegate that works awesome. No boost creep/spike problems with 2 years and 30K miles of use.
SloS13
Ive got a tial and its rock freaking solid
Nathan
klattr1 wrote:Why go with something that is fishy?
Because I allready bought it, and cant afford to replace it ;) I'll just use a higher pressure spring then and see how it works.
klattr1
good luck
Nathan
Hehehe, well if I find I do have a problem with it I'll ***** a lot and find the money to replace it :) So what was this thread about again?
klattr1
Nathan wrote:Hehehe, well if I find I do have a problem with it I'll ***** a lot and find the money to replace it :) So what was this thread about again?
i know right, a lil off topic but informative
C-Kwik
Nathan wrote:Well, once it stopped creeping would it hold steady? I'll be happy if it will just hold 17 or so psi and know somebody it's working quite well for...at around that level and higher.
Well it would, but it progressivley was getting worse over time. I only boost about 7 psi. It started creeping to 8. Then 9. Then 10 and I said forget that and replaced it. I'd rather be safe than sorry when it comes to boost. After I replaced it, I tore it apart to try to figure out why it might be doing that. Nothing looked wrong. There was no reason why it should have allowed overboost, but it did. This was more disturbing to me than anything else...
Nathan
Thanks for the response, it seems one of the biggest issues is creep, it's what happened to Structure too I noticed :(
d240t2
It's a lot cheaper to sell the deltagate and buy a Tial than it is to replace the engine that you blow from overboosting.
When you come tell us that your deltagate took a crap, overboosted, and blew your engine, I will laugh and think "I told you so."
Nathan
It wont blow.
Edit: forged internals, freshly rebuilt, JWT ecu with 75# injectors, Z32 MAF...I can't see how it could possibly overboost too fast for the rest of the fuel system to keep up until I lift off the throttle.
