Turbo water lines
skdline63
hey guys im just top mounted my gt2876R and want to know if its ok to make the water line go back to that bung in the block instead of running it arond the back of the motor, because im getin rid of all the unessary pipes. any help would b great thanks
Modified by skdline63 at 3:27 AM 6/30/2008
Kalypso
did you figure this out?
I was doing a search on coolant and oil lines,
I want to replace my lines but I am worried that It might be tough with the motor inside the bay already - have you been able to do it?
Two-Fortee
Car: 180sx.
I replaced my lines with takas just fine with the engine in the bay if thats what your asking...
articzap
Car: 2014 F150 FX4
Isn't the return line from the turbo to the bung on the block and the feed line comes from behind the motor.
Kalypso
Two-Fortee wrote:I replaced my lines with takas just fine with the engine in the bay if thats what your asking...
YES!!
ok then I know I can do it.
idahotuner suggested removing the transmission crossmember so that the motor sags back.
but im glad I wont have to
