Turbo upgrade
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
well, im a slightly shorter white guy with brown(sometimes blond when ive been in the sun all summer) hair and blue eyes. ill bet you could scare me well enough. dee however, would just rip your arm off and beat you to death with it.
- tim
boost_boy
Naahh man, I'm a 143lb light-brown brotha that's gotten too old to fight. I've never been beat-up before because all the bullies got shot with my BB guns. Imagine what I'd shoot you with now;) and I do have a very low tolerance for ignorance, but you guys are the best; ignorant, but the best.
Dee
redamnavit
Spectre23 wrote:If you go bigger than the GT28R, expect to buy a new manifold, even if it is just the GT25R (has a bigger compressor housing than GT28R I think). I just put a GT28R (not the GT28RS) on my CA and the compressor housing only clears the manifold my 0.020". So of course no heat shields would fit back into place. So I would assume the GT25R wouldn't fit at all unless you got a new manifold or made a spacer for the stock one and got longer studs for it.
Spectre, do you have any pictures of how the GT28R fits on your manifold? How do you like it overall? As my turbo apparently ate its thrust bearing I'm considering one of those...
float_6969
Nothing like bringing a thread back on topic 3 months after it died. JK man! I'm glad you're using the search button. Rock on.
JDMSIL80
Back from the dead
Have we come to the conclusion that GT25R is the best bolt-on turbo on CA18DET?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
JDMSIL80 wrote:Back from the dead
No, we have not come to that conclusion. GT25/40R requires some new oil lines. you are better off going with an S14/15 T28, GT28R, or a GT2871R if needed as all those will be a bolt-on affair.
zero_gripS13
Car: soon to be 95 s14 hopefully
what is need to fit a garret t3 turbo on a stock manifold?..i found a website that offers t3 turbo that are remanufactured (60 trim compressure, .63 a/r turbine housing, internal gated for 500$)
float_6969
First of all, thank you for searching! I loved this thread! In answer to your question, I would be concerned about a T3 clearing the stock manifold. If it will, then you will need to cut off the T2 flange, weld on a new T3 flange, and then get oil feed and drain lines made. If it is liquid cooled, you will also need to find, or have made, coolant lines. Lastly you will have to have a custom downpipe made with a bung for an O2 sensor. That shouldn't be major though. Finding the appropriate flange will be the hard part.
mbmbmb23
zero_gripS13 wrote:what is need to fit a garret t3 turbo on a stock manifold?..i found a website that offers t3 turbo that are remanufactured (60 trim compressure, .63 a/r turbine housing, internal gated for 500$)
Buy this: http://www.horsepowerinabox.co...2.htm
....and get some custom oil lines made. I'm not sure if a Skyline GTST T3 downpipe would mate up, so you may need to get a custom one made. You can buy a T3 outlet flange from ATP turbo or possibly the site I linked.
-m
Dattebayo
I have to jump in and ask a question too...
I see that the GT28RS has a .64 exhaust housing (just like my SR turbo) with a .62 trim. What compressor housing and trim (also where can I get it) do I need to get a T28 sized compressor on my SR20 S13 turbo?
I know, i know about "having someone build it for me", I dont care I will and can get most of the work done myself.
I just dont have the information.
boost_boy
No more turbo related posts. Mods, I know you guys see this stuff and if not, forgive me. We've discussed turbochargers till we were blue in the fact and literally trying to kill each other to get our points across. Please search, SEARCH, and SEARCH again.
Dee
